Fuel pump swap
240,009 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
CARLTON6270
I have the vehicle listed above a two-door model that I just installed a new fuel pump in. It's the pump with the filter built into the module. I also have a 1997 four-door Blazer that the fuel pump just went out. This pump had a strainer, and the float position was 180° in the opposite direction. My question is, will the new pump from my two-door operate correctly enough to supply fuel to my spider injectors? I was able to get it installed after modifying the floats position. I had a mechanic, whom happens to be a Blazer enthusiast, tell me it didn't matter, and that all of the pumps are interchangeable. Now that I've installed it, my girlfriend points out a discussion from another reputable forum in which one of the members was very adamant about them not being interchangeable. As stated, I did modify the float, knowing my gauge may not read correctly, in order for it to fit. Will it work as is or should I use the old module, and just remove the pump from the new one & put it in the four-door module?
Feb 6, 2022 at 9:25 AM
BORIS K
  • 836 POSTS
The physical fuel pump is identical on either model.
Either model uses the CSFI or Spider fuel injection system
Fuel pressure, with engine running, should be at 60-66
PSI (4.1 to 4.5 bar).
You could carry out a fuel [pressure test to verify that the correct pressure is supplied.
How to test fuel pressure:
https://youtu.be/s_Cf8snuI5Y
How to replace the fuel pump:
https://youtu.be/bCcueO4ALxQ
Please let us know how you get along.
Cheers, Boris
Feb 6, 2022 at 4:37 PM
CARLTON6270
Thanks for the advice. I did get the pump installed before I got your reply, it did work. The only issue was the fuel gauge not working, which I already knew was going to be the case.
Feb 15, 2022 at 6:50 AM
That is great. Thanks for coming back to update us on your progress.
Please feel free to get a new post started if you want help with the fuel gauge issue as well.
Thanks for using 2CarPros.
Feb 18, 2022 at 10:27 AM
