1997 Chevy Blazer fuel pump
SWANN294
  • 1997 CHEVROLET BLAZER
  • 6 CYL
  • 210,000 MILES
Putting in a new fuel pump, do you guys have manual for installin pump and whats the best pump to install for this auto?
Thursday, January 28th, 2010 AT 10:08 AM
RACEFAN966
  • 5,029 POSTS
I would buy a Delphi pump this is the factory brand and it can be bought at most parts stores too. As for replacing it I can walk you through the proccess. You will need to drop the fuel tank so it isn't much fun and hopefully the tank isn't full.
Thursday, January 28th, 2010 AT 10:19 AM
SWANN294
Can you instruct me on how to install? I have a friend helping me and he has more mechanic know how than me. Thanks.
Thursday, January 28th, 2010 AT 10:34 AM
RACEFAN966
  • 5,029 POSTS
Ok raise rear of car and block wheels. Now disconnect the battery. Get a jack and board to support the tank. Now remove the straps and disconnect the fill and vent hose at the tank and lower tank. Now watch the top of tank and get it low enough to disconnect the electrical connector and then the fuel lines to the tank now lower tank. Now remove the lock ring and remove the sending unit which has the fuel pump on it. Now remove the pump from the sending unit and put back in reverse order.
Thursday, January 28th, 2010 AT 10:45 AM
