My engine will not start up and run?
There are a number of things we need to start with. First and foremost is scanning for codes.
Next we need to have the battery load tested because you may be correct that this is a battery issue.
If these do not pan out then here is a guide on this issue in general. We need to start working through this.
https://youtu.be/dCjmRL3p4Cs
Let me know what questions you have questions but if these things are not the issue I am putting my money on a fuel pump issue. However, the cold weather points to a battery. If working through that last guide you get to a fuel issue here is a final guide on how to test the fuel pressure:
Let us know what you find. Thanks
Monday, January 25th, 2021 AT 1:40 PM (Merged)
