Engine low power
RENEE L
  • ADMIN
  • 1,260 POSTS
Hello ASHELY,
Thank you for visiting 2CarPros. Here is a helpful link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel system pressure, regulator and fuel pump in less than fifteen minutes:
If you need further assistance please come back to the site we are always happy to help.
Kindest regards,
Renee
Admin
Wednesday, December 9th, 2020 AT 3:32 PM (Merged)
HILLAROSE
  • 1991 BUICK PARK AVENUE
  • 96,000 MILES
A few weeks ago my car started vibrating when I get to about 50 and try to accelerate. The other morning I left for school and about a mile down the road it quit accelerating. I had to push the pedal to the floor to get it to 30mph. I assumed it was the cat. Converter. I had my boyfriend cut it off and put on a flex pipe (no emissions testing here). I've already replaced the air shaft sensor, coil pack and ignition module along with the alternator, steering pump, water pump, spark plug wires. I dont have the cash to just take it in. I'd rather just start with the easy obvious things. Any ideas?
  • 109,885 POSTS
I would start with checking fuel pump pressure. There are directions on our home page under the DIY section. Next, if the check engine light is on, have the computer scanned to identify trouble codes. Most parts stores will do it for free. It could deal with a bad throttle position sensor or major vacuum leak too so keep that in the back of your mind.
ROBERT CHOW
I had exact same problem with the 1998 buick park avenue that has 86k when I bought used; after drove for 5,000 miles, it accelerate short distance than stop but engine still maintain same rpm. I checked tranny fluid, was ok. I drove it the next morning but the car doing the same thing. After cool down for 15 minutes I made it to the auto repair shop. It was a major shock it to my wallet; rebuilt tranny set me back $2,500. Buick is known for tranny going south once reachs over 75K to 100k miles. The previous owner must have known this problem.
