Will not stay started?
131,951 MILES • 4.3L • 2WD • AUTOMATIC
JODI LAYMAN
Have to prime it to start then it won't stay started. It keeps shutting off when the RPMs go down, have to prime again to start.
Oct 4, 2022 at 11:16 AM
  • 110,248 POSTS
This can be a few different issues. The idea that you need to prime it sounds like it could be fuel related. Have you checked the fuel pump pressure? If not, that is where I would start.
Here is a link that explains in general how it's done:
Also, if the check engine light stays on when it starts, we really need to retrieve diagnostic trouble codes. If the vehicle is drivable, most parts stores will do it for you free of charge. If it isn't, see if you can get your hands on one to check.
Here is a quick video showing how it's done:
https://youtu.be/b2IJGfImVvw
Oct 4, 2022 at 1:20 PM
