I have been back to a repair shop about 4-5 times to try and have a knock at the very least known to me. I have had all tie rods (front inner & outer) replaced, both front lower control arms replaced, and the k cradle frame mounts replaced(gm). Other parts aftermarket moog.
I had 2 bad (loose) frame mounts, but all 6 repaired.
I have had discount tire replace and go through 4 sets of new tires because every single one seemed to be out of round... I know am riding Michelin defender and still have the tires walking with a 30mph roll. Been balanced and aligned numerous times. For my tire issue I have tried to get discount tire to perform the road force test with their machine, but never could get to that point.
I have a performance motor mount installed from Northstarperformance- if you know what they are I will describe what has happened. But the function of the mount is solid and working 90% strong. They have updated the mount because of one of their issues I am going through now. Regardless it works.
I have tried to get the strut mounts checked by techs and they tell they are ok. I have had them look at my axles and say they are ok. I personally think there is some concern with the halfshaft as they vibrate a lil through R,N,D.
I am at a loss and do not want to take it to a dealer because of trust issues in my area.
The noise can be heard/felt during initial stopping and acceleration. Also with turning as well.
Apr 30, 2016 at 12:09 PM
