1995 Ford Windstar Catalytic Converter Fix
HAMCIENDA
I have 1995 Ford windstar, 3.8l 6v SFI
170K miles.
My catalytic converter is plugged and needs to be replaced. I live in rural California.
Dealer and mechanics wants close to $2000 for new converter....because I live in CA. Eastern models are $302-358
What is the difference in CA/vs/ rest of the world converters?? Can I just buy one that will fit my van - even if is not "California model" ?? Where I live we are not required to do smog checks at all
(only when changing ownership)
My van is old and I do not see spending additional $2000 but would like to fix it to use 2-3 more months before I can buy new car.
Here is info I found on www.partstrain.com
#4551
Catalytic Converter Catco $302.95
Vehicle:
1995 Ford Windstar
Fits Engine – Chassis:
3.8L, 6 Cylinder — Windstar
Description:
Direct Fit, Original Replacement Catalytic Converter, Complete, Stainless Steel Piping
Fit Note:
Except California Models
IF I BUY THIS WOULD IT FIT MY VAN???
Please help with suggestion.
Thanks
Vera Hamann
Apr 19, 2007 at 8:04 AM
MERLIN2021
  • 17,250 POSTS
No you will be better off getting a universal converter for the van and cutting the pipes to the right length. California model exhaust converters are ususally longer than the rest. Universal is way cheaper and all you'll need is a sawzall with metal blade!
Apr 19, 2007 at 8:15 AM
Suggested Repair
Use a universal catalytic converter and cut the exhaust pipes to the correct length with a metal-cutting saw. California converters are typically longer than non-California units.
Conversation Summary
The owner of a 1995 Ford Windstar 3.8L with 170,000 miles has a plugged catalytic converter. Dealers quoted nearly $2,000 for a California converter, while non-California units cost about $300. The owner asked whether a non-California direct-fit converter would fit and noted that routine smog checks are not required locally. The expert recommended a cheaper universal converter cut to the proper pipe length, explaining that California converters are usually longer.
