2002 Ford Windstar Running Rough
CCBRAD
I've got a 2002 Windstar SE with 118K.
I need to keep it on the road for 2 - 3 years (40 - 60K more miles)
I've replaced battery, belts, tie rods, cv joints to name a few.
What repairs should I plan for so that I don't break down on the road?
I'm thinking water pump, fuel pump ...
Thanks
Sep 17, 2007 at 3:27 AM
SERVICE WRITER
  • 9,123 POSTS
If it ain't broke, don't fix it. You are not only cuasing more expense, you may cause more greif if a replacement part goes belly up.
Do your maintenance- fuel filter, transmission filter, air filter, plugs, wires, change the coolant, Change the power steering fluid or brake fluid if discolored. Keep the oil changed every 3000 miles/3 months, clean the intake valves with seafoam, Clean the MAF with electriacl cleaner spary.
Sep 17, 2007 at 12:55 PM
Suggested Repair
Do not replace parts that are not failing. Perform maintenance: fuel, transmission, and air filters; spark plugs and wires; coolant; discolored power steering or brake fluid; oil every 3,000 miles or 3 months; clean intake valves with Seafoam and the MAF with electrical cleaner.
Conversation Summary
The owner of a 2002 Ford Windstar with 118,000 miles wants it reliable for another 40,000 to 60,000 miles and asked whether to plan water pump and fuel pump replacement after already replacing the battery, belts, tie rods, and CV joints. The expert advised against replacing working parts and recommended routine filter, fluid, ignition, and intake maintenance instead.
