I ran out of gas, gas it up, started a bit, now it won't start at all, how do I unflood it. Help.
Apr 11, 2007 at 9:38 AM
Charge the battery overnight and jump-start the truck, which is what got it running. If it is flooded, wait and then clean and regap fouled spark plugs. After running out of gas, also consider a damaged electric fuel pump; a brief spray of starter fluid into the throttle body may help it start.
The owner ran out of gas, refueled, and then could not restart the truck and asked how to unflood it. Year and engine size were unknown. Advice was to wait, clean and regap fouled plugs, check whether the electric fuel pump was damaged, and try starter fluid in the throttle body. The owner later reported it started after being plugged in overnight and given a boost.
