1988 Ford Motorhome Dies After Jump
BILL IN BC
I am working on a 1988 motorhome on a ford chassis. When it was being boosted the battery was hooked up backwards. Now when we start it the engine dies as soon as we disconnected the boosting battery. I have checked some of the fusible links and they seem fine. What else should I be looking for? :cry:
Mar 21, 2007 at 9:54 PM
SIRGIBBY
  • 32 POSTS
Check any and all fuses.. But if it dies when you disconnect the other battery i'd be leaning towards the alternator.. Might have fried some of the components inside there..
Mar 22, 2007 at 11:18 AM
MERLIN2021
  • 17,250 POSTS
More than likley it is a fried alt. But try dissconcting the cables and reconnecting them.
Mar 22, 2007 at 12:34 PM
BILL IN BC
Yes, it was the Alternator. Thanks for the input Guys. :D
Mar 22, 2007 at 8:44 PM
Suggested Repair
Check all fuses and fusible links, disconnect and reconnect the battery cables, and replace the alternator if the engine dies when the boost battery is removed. Reverse polarity likely damaged the alternator.
Conversation Summary
A 1988 motorhome on a Ford chassis was jump-started with the battery connected backwards. Afterward the engine died as soon as the boosting battery was disconnected, though some fusible links looked fine. Replies suggested checking all fuses and reconnecting the cables, and pointed to a damaged alternator. The owner later confirmed the alternator was the cause.
