1995 Ford Escort Cold Stall After Revs
ASH BLEWER
Hi there, i posted this subject a while back and still havent managed to rectify the problems i am having , so if any you could help it would be greatly appreciated.
The car will start (after 10 mins battery charging off a slave due to lack of use, the battery has gone flat) whilst the engine is cold its sounds very weak and as if it is about to cut out, which it does after giving it revs, i presume this is once the automatic choke is no longer in action, I have been told this is the idle speed control valve and that this is a common fault, if i replace this part , is it the likely solution? thanks guys
Feb 2, 2006 at 9:56 PM
ASH BLEWER
[quote="Ash Blewer"]Hi there, i posted this subject a while back and still havent managed to rectify the problems i am having , so if any you could help it would be greatly appreciated.
The car will start (after 10 mins battery charging off a slave due to lack of use, the battery has gone flat) whilst the engine is cold its sounds very weak and as if it is about to cut out, which it does after giving it revs, i presume this is once the automatic choke is no longer in action, I have been told this is the idle speed control valve and that this is a common fault, if i replace this part , is it the likely solution? The car is a 95 'M' reg, 1.8 ghia, zetec efi engine (multi point) cheers
Feb 3, 2006 at 12:21 AM
CHEVY350GUY
  • 109 POSTS
have you tested fuel pressure, fuel flow, spark, condition plugs wires, have yoy cleaned the throttle chamber, anything?
Feb 3, 2006 at 1:01 AM
ASH BLEWER
I have replaced the 'air flow sensor' and all spark plugs. still has the same problem, i even replaced the battery with a new one to eliminate that as a problem
Feb 3, 2006 at 1:25 AM
CHEVY350GUY
  • 109 POSTS
look in to possible problems with the fuel system. id like to know the results before you buy a part you may not need. start with the filter, after that do a fuel pressure test. if every thing in the fuel system checks out ok then look into the valve being the problem.
Feb 3, 2006 at 3:43 AM
Suggested Repair
Before replacing the idle speed control valve, check the fuel system: inspect or replace the fuel filter, then perform a fuel pressure test. If fuel delivery checks out, then investigate the idle speed control valve.
Conversation Summary
The owner of a 1995 Ford Escort 1.8 Ghia with a Zetec multipoint EFI engine reports that the engine starts but idles weakly when cold and stalls after revving, which they associate with the automatic choke coming off. They were told the idle speed control valve is a common fault and asked whether replacing it would fix the problem. They had already replaced the airflow sensor, spark plugs, and battery with no improvement. The expert advised checking the fuel system first, starting with the fuel filter and a fuel pressure test, and only considering the idle valve if fuel delivery checks out.
