1995 Ford Taurus No Start After Scan
BOILERMAKER084
I have a 95 Ford SHO MTX - engine is 3.0 DOHC, Mileage is 125K. I hooked up a Actron 9110 Scan Tool using the Ford OBD1 cartridge and OBD1 cable connector supplied with the tool to the engine compartment connector ( 6 prong (black) + 1 pigtail (gray)). The Scan Tool ran though the KOEO program fine. When I changed to run the KOER codes the engine would not restart - it finally did and died shortly after, during the restart the tachometer was not working. Is it possible the Scan Tool shorted out something in the computer? What are the next steps to try to diagnose the problem? I read in an SHO forum after the incident that the pigtail lead for the Scan tool should not have been connected to the grey pigtail on the engine harness? Was this the problem - and the tach has now been shorted out? Thanks.
Apr 11, 2007 at 7:48 AM
2CARPRO JACK
  • 11,533 POSTS
See what you lost, spark or fuel. If spark be sure that you have power to the coil with key on.If you have fuel pressure, but plugs are dry you will have to test for pulse at the injectors with a noid light. I personally have never seen a scanner short out a car before...... very strange. Doesnt mean it cant happen
Apr 12, 2007 at 1:20 AM
Suggested Repair
Determine whether spark or fuel was lost. If there is no spark, verify power to the coil with the key on. If fuel pressure is present but the plugs are dry, test injector pulse with a noid light. A scan-tool short is uncommon but not impossible.
Conversation Summary
The owner of a 1995 Ford SHO with a 3.0 DOHC engine used an Actron scan tool for KOEO and KOER tests. After switching to KOER, the engine would not restart, then died, and the tachometer stopped working. The owner worried that connecting the gray pigtail had shorted the computer. The expert recommended checking spark versus fuel, coil power, and injector pulse, noting that a scanner short is unusual but possible.
