1995 Ford Taurus Starts Then Shuts Off
DOLORES MARTIN
My 95 Ford Taurus starts and immediately shuts off and the battery light comes on. I sometimes have to start it several times and rev the engine to keep it going. This usually happens after it has sat for at least 1/2 a day but not always. My mechanic has tried replacing the relay module and suggested I turn the car on and wait a second or two before starting it. This worked for about a week but now the problem's back. Any suggestions? I have about 97,000 miles on it.
Jan 21, 2006 at 12:48 PM
LOVESCARS
  • 359 POSTS
Besure the clamps on the battery are not corroded as well as the wire. This could also indicate and alternator problem have the alternator tested at a local auto parts store many of them will do this for free as a courtesy and potential sale.
Jan 25, 2006 at 1:31 PM
Suggested Repair
Inspect the battery cable clamps and wires for corrosion. Have the alternator tested at a local auto parts store, which often offers free testing.
Conversation Summary
A 1995 Ford Taurus with about 97,000 miles starts and immediately shuts off, with the battery light coming on. The owner sometimes must restart it several times and rev the engine to keep it running, often after it has sat for at least half a day. A mechanic replaced the relay module and advised waiting a second or two after turning the key on before starting; that helped briefly, then the problem returned. The expert advised checking the battery clamps and wires for corrosion and having the alternator tested.
