2000 Ford Windstar No Front Heat
CRISTINA
  • 9 POSTS
I own a 2000 ford windstar v6 with about 176,000 km. The heater quit working in the spring but it wasn't a big deal because it was warm out. Recently we replaced the thermostat trying to repair it. It partially worked because now I have heat in the back of the van. Problem is there's no heat coming out in the front. Any suggestions as to why and how to fix it.
Oct 22, 2007 at 5:09 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b66e7e427f="cristina"]I own a 2000 ford windstar v6 with about 176,000 km. The heater quit working in the spring but it wasn't a big deal because it was warm out. Recently we replaced the thermostat trying to repair it. It partially worked because now I have heat in the back of the van. Problem is there's no heat coming out in the front. Any suggestions as to why and how to fix it.[/quote:b66e7e427f]
its your blend door actuator
right side of dash
some have it almost behind the radio and ashtray
it has a square plug wires
Dec 20, 2016 at 1:09 PM
Suggested Repair
Inspect and replace the blend door actuator on the right side of the dash, sometimes nearly behind the radio and ashtray. It uses a square wiring plug.
Conversation Summary
The owner of a 2000 Ford Windstar with about 176,000 km lost heater function. After replacing the thermostat, rear heat returned but the front still has no heat. The expert identified the blend door actuator, located on the right side of the dash and sometimes nearly behind the radio and ashtray, with a square wiring plug.
