Ford Windstar Coolant Loss and Overheating
MOONCHILD
MY HEATER STOPPED WORKING, NOW I'M LOSING COOLANT, I DON'T SEE ANY LEAKS IT'S AS THOUGH IT'S VANISHING. I REFILLED THE RADIATOR AND START TO DRIVE A SHORT DISTANCE WHEN THE TEMPERATURE LIGHT COMES ON THAT THE ENGINE IS RUNNING HOT . MY MECHANIC REPLACED THE THERMOSTAT, BUT DID NOT DETECT ANY LEAKS... ANY HELP WOULD BE APPRECIATED!!!
Mar 29, 2006 at 8:01 AM
PEPPERMRJ
  • 1,158 POSTS
Check the oil for coolant. Will look like a chocolate milkshake on the dip stick and filler cap. Could be a waterpump. They are tuff leaks to find at first.
Good hunting. :)
Mar 29, 2006 at 11:51 AM
Suggested Repair
Check the engine oil for coolant contamination, which can look milky on the dipstick and filler cap. Also inspect the water pump, since those leaks can be hard to find at first. The thermostat has already been replaced and no external leak was found.
Conversation Summary
A Ford Windstar owner reports the heater stopped working, coolant is disappearing with no visible leaks, and the engine runs hot after a short drive even after the radiator is refilled. A mechanic replaced the thermostat and found no leaks. The expert advised checking the oil for coolant contamination and noted a water pump leak is possible and often difficult to spot initially.
