1996 Ford Windstar Heater AC Out
ELETEACH03
I have a 1996 Ford Winstar with approx. 180,000 miles and it is a 3.8 engine. I was running my defrost to defog my window and all of a sudden it quit. I have both front and rear heat. There is nothing coming from my heater or AC at all. I am thinking to check fuses first and then relays. But i cant tell which fuse it is cause someone has taken the cover from my fuse area inside. Can you help?
Nikole Benson
Aug 25, 2007 at 10:46 AM
  • 75,988 POSTS
[quote:d4910e15cb="eleteach03"]I have a 1996 Ford Winstar with approx. 180,000 miles and it is a 3.8 engine. I was running my defrost to defog my window and all of a sudden it quit. I have both front and rear heat. There is nothing coming from my heater or AC at all. I am thinking to check fuses first and then relays. But i cant tell which fuse it is cause someone has taken the cover from my fuse area inside. Can you help?
Nikole Benson[/quote:d4910e15cb]
Interior fuse junction panel under left side of instrument panel-you'll be looking for no.36 which has a 30amp fuse.
Aug 25, 2007 at 1:19 PM
  • 75,988 POSTS
The blower motor is it coming On.
Aug 26, 2007 at 11:18 AM
  • 75,988 POSTS
Madam
In the instrument panel fuse box-you need to find all these fuses no.21 10amp no.36 30amp no.39 30amp.
The no.21 10amp powers all the circuits -by using no.21 and no.36 to transfer power to the blower motors /relays and resistors.
If you have a bad AC/Heater selector switch nothing is gonna work, it has to go thru there for the other stuffs to work.
Aug 26, 2007 at 1:06 PM
  • 75,988 POSTS
[quote:f5d71898c5="rasmataz"]
To: rasmataz
Posted: Sun Aug 26, 2007 4:21 pm
Subject: Re: heater, ac not working
Nothing is working. Not the rear or the front.
Madam
If you have a bad AC/Heater selector switch nothing is gonna work, it has to go thru there for the other stuffs to work.[/quote:f5d71898c5] It's the pink wire that comes from the 10amp to the AC/HTR selector switch or the switch itself.
BTW your electrical passages in the AC/Heater is worst than a can of Chef Boyardee Spaghetti it is not a DIY, you need to bring it in. You need to be a competent electrician to nail this one.
Please! do not use PM stay here so the others can see it and help out-maybe!!!! we'll wait and see who is gonna step my toes. Come on down!!!
Aug 26, 2007 at 1:08 PM
Suggested Repair
Check the instrument-panel fuses 21 (10A), 36 (30A), and 39 (30A), confirm whether the blower motor runs, and inspect the pink wire to the A/C-heater selector switch or the switch itself. If the fuses are good, have a qualified technician diagnose the circuit rather than attempting a complex DIY repair.
Conversation Summary
The owner of a 1996 Ford Windstar 3.8 reported that defrost, heat, and A/C airflow suddenly stopped at both front and rear. The expert identified instrument-panel fuses 21, 36, and 39 as powering the blower circuits, relays, and resistors, and suggested checking the blower motor, the pink wire to the A/C-heater selector switch, and the switch itself. The expert also said the wiring is complex and recommended professional diagnosis.
