WINDSTAR A/C PROBLEM
MRG348
  • 5 POSTS
1998 windstar 3.8 gl automatic .A/C Stopped working,so i checked compressor to see if clutch is engaging- it is not , so i disconnect the clutch terminal wires,then i hook-up some jumper wires from battery to clutch terminal,the clutch engages and the compressor starts turns,the a/c is cold inside van and works properly now. what should i replace ? and where is it located ? please give full details. thank you
May 31, 2007 at 2:32 AM
MRG348
  • 5 POSTS
I CAN'T BELEIVE THAT NO HAS AN ANSWER. 24 VIEWS
Jun 2, 2007 at 2:25 PM
MRG348
  • 5 POSTS
[quote:2afa5e212e="justanold"]HELLO! The very first thing to replace is your attitude. when done get back to me. 8) 8) 8)[/quote:2afa5e212e] SORRY,But you must in a different industry.I am describing my van,which is an automobile,and they do not have attitudes,so i know your answer is incorrect.if you cannot reply intelligently and with a proable solution,then do not reply with ignorant statements.
Jun 3, 2007 at 7:52 AM
MERLIN2021
  • 17,250 POSTS
This is an all volunteer army in here...No one MUST answer anythging!
Jun 3, 2007 at 8:07 AM
MRG348
  • 5 POSTS
I understand that,but i beleive your original diagnose may have been correct coming from its source. i for one will help anyone with a problem with certain blein. i do think that forums are for this purpose,not to show a disciplinary actions.upon your arrival ,i dismiss you , as i do not need to attain your respond.thanks for the ruination of my post.sir,i just do not see fit to donate under these circumstance of lack of usable information.
Jun 6, 2007 at 3:21 PM
