I have a 91 ford tempo lx when I hit the slightest bump it bounces all over if I hit a big bump there is no bouncing just a thud
Dec 6, 2006 at 1:31 AM
Inspect and replace worn shocks or struts. Also check ball joints, strut mounts, and sway bar bushings and end links for play or wear that can cause a thud.
The owner of a 1991 Ford Tempo LX reported bouncing over small bumps and a thud over larger bumps. An expert said the bounce usually points to failed shocks or struts and that a thud can also come from ball joints, strut mounts, or sway bar bushings and end links. The owner thanked the expert; a later comment was anecdotal and did not add a diagnosis.
