1993 Ford Tempo Idle Misfire
i have a 1993 ford tempo..... itll run fine as soon as u start but as it starts slowing down and idleing lower it misfires non stop...... new fuel filter, cap, rotor, wires, plugs..... so i wanna have the ignition module checked but i dont know how to get it off...... its mounted on the distributor...... do i have to have a speacial key or what
May 16, 2007 at 7:58 AM
I'm not sure which one it has, but it's either a torx or hex head security screw. These are available at certain tool or auto parts stores. It sounds like your problem might be the module, like you said, but it might just need dielectric grease on the module where it attaches to the distrbutor. This grease keeps the module from heating up which could cause misfiring. This grease is available at auto parts stores.
May 17, 2007 at 7:06 PM
Suggested Repair
Remove the distributor-mounted ignition module with a Torx or hex security bit from a tool or auto parts store. Apply dielectric grease where the module contacts the distributor so it does not overheat and misfire, and replace the module if testing confirms it is faulty.
Conversation Summary
The owner of a 1993 Ford Tempo says it runs fine right after starting but misfires constantly as idle drops. A new fuel filter, cap, rotor, wires, and plugs have not fixed it. They want to remove the ignition module on the distributor and ask if a special key is required. The expert says the fastener is a Torx or hex security screw available at tool or parts stores, and that dielectric grease on the module-to-distributor contact may prevent heat-related misfiring.
