1993 Ford Tempo High Idle
THE_HYDROXIDE_CHILD
  • 82 POSTS
i have a 93 ford tempo got like 150K miles... it started having idle problems like when ur driving the car it will idle alot higher than normal..... and if u push the clutch in and put it in neutral while driving then release the clutch it will idle really high until u come to a dead stop...... unless u stop it wont idle down..... then once u stop it takes like 10 seconds..... but its idles down...... repalced the MAF sensor and the idle air control valve..... we even replaced a bunch of cracked vaccum hoses..... im just lost with this one.... cuz when we unplug the iac the idle never has a single problem....... but the valve is brand new...... im just lost
May 22, 2007 at 2:16 PM
BLACKOP555
  • 10,386 POSTS
any trouble codes?
May 22, 2007 at 2:31 PM
RUDPRO
  • 224 POSTS
The IAC gets a signal from the computer. The computer gets information from the O2 sensors to adjust the idle. You might want to chek that.
May 22, 2007 at 7:27 PM
THE_HYDROXIDE_CHILD
  • 82 POSTS
no , there is no trouble codes at all.... which is wierd..... ill check the 02 sensor
May 23, 2007 at 3:16 AM
RUDPRO
  • 224 POSTS
You also said you replaced cracked vacuum lines. I would do a thorough check of the vacuum system again. A small leak could be causing it. Also, the IAC valve could be defective even if it's new. I have bought new parts before and they were defective out of the box. It almost sounds like the new IAC valve could be hangng up or working very slowly.
May 23, 2007 at 4:15 AM
J_KUNATH
I had a sim. situation and it ended up being a leak around the intake gasket. Take some starting fluid or carb cleaner and spray around the base of the intake where the gasket is. Hope this helps
May 23, 2007 at 11:36 AM
Suggested Repair
Recheck the vacuum system for small leaks, including a possible intake manifold gasket leak. Also verify the new IAC valve is not sticking or slow, and check the oxygen sensors that help the computer control idle.
Conversation Summary
A 1993 Ford Tempo with about 150,000 miles idles much higher than normal while driving and stays high after the clutch is pressed and the transmission is shifted to neutral until the vehicle comes to a complete stop. The MAF sensor, IAC valve, and cracked vacuum hoses were already replaced, and there are no trouble codes. Unplugging the IAC eliminates the idle problem. Experts suggested rechecking for vacuum leaks, testing for an intake gasket leak, confirming the new IAC is not defective or slow, and checking the oxygen sensors.
