I just bought it.
seems to idle up and down. Also when driving if I get into it, it bogs down and the check engine light comes on.
I think it is the map senser but dont know for sure.
Monday, March 26th, 2007 AT 4:26 AM
MERLIN2021
MECHANIC
Go to autozone and have the codes read. Then post the codes here so we can see what's going on.
SPONSORED LINKS
Monday, March 26th, 2007 AT 9:30 AM
MCFERRANCE
MEMBER
Most likely is the map sensor. It has been a while since I had this problem, but I believe that when you disconnect and plug the vaccuum line to it, the idleing smooths out and this would signify that it is bad.
