1992 Ford F-150 Idle Bogging
NICK21
i have a 1992 F-150 118,000 miles 4wd with a stick. When Im at a stop light or have the clutch pressed in the truck barely stays running. The voltage will drop and the truck bogs down then it goes back to normal. I the does this repeatedly when ever it idles. The truck does have an exhaust leak up front some where if the that helps at all.
May 24, 2007 at 9:36 PM
RUDPRO
  • 224 POSTS
Does the check engine light come on? If it does, have it scanned for trouble codes. Also, fix the exhaust leak. That could be affecting the oxygen sensors reading the exhaust, and the computer getting wrong information.
May 25, 2007 at 6:08 AM
NICK21
[quote:0f80dd1431="Rudpro"]Does the check engine light come on? If it does, have it scanned for trouble codes. Also, fix the exhaust leak. That could be affecting the oxygen sensors reading the exhaust, and the computer getting wrong information.[/quote:0f80dd1431]
I did come for a while then it went out
May 25, 2007 at 5:24 PM
Suggested Repair
Scan for stored trouble codes and repair the front exhaust leak, which can cause incorrect oxygen-sensor readings and idle problems.
Conversation Summary
A 1992 Ford F-150 with a manual transmission nearly stalls at idle, with the voltage dropping and the engine bogging before recovering. The owner also reports a front exhaust leak and a check engine light that came on briefly and then went out. The expert advised scanning for trouble codes and repairing the exhaust leak because it can mislead the oxygen sensors and computer.
