1991 Ford Tempo Rough Ride Bounce
BONZAI09
I have a 91 ford tempo lx when I hit the slightest bump it bounces all over if I hit a big bump there is no bouncing just a thud
Dec 6, 2006 at 1:31 AM
CARUNDELL
  • 602 POSTS
[quote:6227ce74c6="bonzai09"]I have a 91 ford tempo lx when I hit the slightest bump it bounces all over if I hit a big bump there is no bouncing just a thud[/quote:6227ce74c6]
Hey bonzai,
Sounds like some serious suspension issues there! Bouncing usually indicates strut/shock failure, and will also cause a clunk/thud, though there may be other front end issues causing the noises. Ball joints, strut mounts,sway bar bushings and end links.
Regards,
Chris
Dec 6, 2006 at 1:35 AM
BONZAI09
maybe I will just blow it up
Thanks for your response
Dec 6, 2006 at 4:26 AM
HEY_WIRE
  • 25 POSTS
ha yeah i know what you are talking about i had a little crappy nissian manly for just playing around and trashing and it had no springs i could hit the brakes and let off and let the car look like it had front hydrolics you might wont to get it fixed though i ran over a really big rut and bounced so much it bottomed out and radiator replaced itself right into the fan i didnt feel like fixing it or spending the money so i sold it to a salvage yard for $200
good luck
Dec 6, 2006 at 2:36 PM
Suggested Repair
Inspect and replace worn shocks or struts. Also check ball joints, strut mounts, and sway bar bushings and end links for play or wear that can cause a thud.
Conversation Summary
The owner of a 1991 Ford Tempo LX reported bouncing over small bumps and a thud over larger bumps. An expert said the bounce usually points to failed shocks or struts and that a thud can also come from ball joints, strut mounts, or sway bar bushings and end links. The owner thanked the expert; a later comment was anecdotal and did not add a diagnosis.
