1992 Ford Tempo Cracked Manifold
DEMA
Hi I was wondering if you can give me an estimate on how much it would be to get the manifold fixed on a 92' FORD TEMPO it has 173,000 miles on it. The manifold is cracked. thank you
Dec 19, 2006 at 12:34 AM
BRUCE HUNT
  • 3,754 POSTS
There are two manifolds, intake and exhaust. Which one. I would bet you are talking about the exhaust. If so, that depends on whether you put on a new one or a good used one. Labor would be a couple of hours. Call around yourself to find a price on a new manifold and a used one as well.
Dec 19, 2006 at 12:58 AM
Suggested Repair
Confirm whether the cracked part is the intake or exhaust manifold. Price both a new and a good used manifold, and expect roughly a couple of hours of labor.
Conversation Summary
The owner of a 1992 Ford Tempo with 173,000 miles asked for a repair estimate for a cracked manifold. The expert said to identify whether it is the intake or exhaust manifold, likely the exhaust, then compare new and used part prices locally. Labor was estimated at a couple of hours.
