1991 Ford Tempo Alternator Belt Squeak
PYRRAH316
When I first start up the car, it starts fine. After I drive it for 10 - 15 mins and shut it off, then try to turn in back on, the AMP light comes on and the alternator belt starts squeeking and sometimes the car dies a couple seconds afterwards, sometimes it will stop squeeking and I can drive it. Any ideas as to what might be the problem?
Feb 2, 2006 at 6:11 AM
CHEVY350GUY
  • 109 POSTS
first replace the belt.the belt is squeeking because it is too loose or too worn. this will make the light come on.
Feb 2, 2006 at 8:43 AM
Suggested Repair
Replace the alternator belt, which is likely too loose or worn. A slipping belt can cause the squeaking and the AMP light.
Conversation Summary
The owner of a 1991 Ford Tempo reports that the car starts fine when cold, but after 10-15 minutes of driving and a shutdown, restarting causes the AMP light to come on and the alternator belt to squeak. The engine sometimes dies shortly afterward, though the squeaking sometimes stops and the car can be driven. The expert advises replacing the belt first, explaining that a loose or worn belt causes the squeaking and the warning light.
