[quote:6f9f4d7646="Albert"][quote:6f9f4d7646="carundell"][quote:6f9f4d7646="Albert"]I have a ford tempo year is 1988, and the heater used to work before but i left it sitting in my back yard for about 4 months and now it dont work? So what seems to be the problem? Thank you.[/quote:6f9f4d7646]
Hey albert,
Are you saying the blower is not working? Or the blower works and it doesn't blow heat. Please be more specific! Let us know
Chris[/quote:6f9f4d7646]
Im not sure, I turn on the heater and air comes out but the air is cold, i leave the car on for a while and it never warms up. so i dont know how do i find out if the blower isnt working?[/quote:6f9f4d7646]
Hey albert,
Some things to check, first though, if air is coming out of the vents than your blower is working.
1. your temperature control operates on engine vacuum, check the small plastic vacuum line that goes thru the firewall, these sometimes crack and break.
2. check the hoses to the heater core, if they are not both hot then is a heater core problem (clogged)
Chris
Dec 16, 2006 at 9:38 PM
