1992 Ford Tempo Air Always to Windshield
If this valve is working, then you know you have vacuum driving the system. Now you have to find out why that particular motor is not getting the vacuum or not working. If you dont get the outside sir thing to work, then you have a vacuum problem, and all of the vacuum motors dont work.
Suggested Repair
Check whether the outside/recirc door responds to vacuum. If it does, the shared vacuum supply is working and the panel-defrost door vacuum motor is not receiving vacuum or has failed. If the outside-air door does not work, diagnose a vacuum supply problem affecting the climate-control vacuum motors.
Conversation Summary
The owner of a 1992 Ford Tempo 3.0L reports that airflow stays directed at the windshield no matter which climate-control mode is selected. The expert explains that vacuum motors control the doors and identifies the panel-defrost door vacuum motor as the likely stuck component. They recommend testing the outside/recirc door to confirm vacuum supply, then tracing vacuum to that motor if supply is good, or diagnosing a system vacuum problem if it is not.
