1993 Ford Tempo I have tried everything
COWBOY200923
  • 1993 FORD TEMPO
Engine Mechanical problem
1993 Ford Tempo 4 cyl Front Wheel Drive Automatic high miles
yeah I hope someone can tell me what I am doing wrong with fixing my car. Two weeks ago it was broke down and wouldn't start for nothing. So I put a new battey in it and drained the old gas out and put fresh gas in. Well it fired up but wouldn't stay runnin so I screwed the screw on the thotal arm in and it reved a lil bit high but stayed running I ran great for two weeks and then staled out and now will not fire up it turns over but not getting gas from the filter to the motor so I think its the injectors but I wanna know if there is a way to take them off and clean the line at all I know the fuel pump works I have tested it but it just isn't gettin fuel to the motor. Can anyone tell me what I need to do to try and fix this pos heck thats what I get for not buying a truck
Wednesday, September 9th, 2009 AT 2:44 PM
FIXITMR
  • 9,990 POSTS
If fuel pump works/is good then gas should come out at filter! Hope you didn't use injector/other cleaner product as I have seen this stuff wreck injectors! Sorta sounds like pump was weak and finally died! Your rambling is alittle hard to decipher! Come back with more accurate info.
Wednesday, September 9th, 2009 AT 4:41 PM
