1993 Ford Tempo car wont start
AMISENER0889
  • 1993 FORD TEMPO
Engine Mechanical problem
1993 Ford Tempo 4 cyl Front Wheel Drive Automatic
i have had my car worked on a few times in the last few months. I just got my car out of the shop again a little of a week ago. My car wont start. It turns over but wont actually start. The shop just replaced the fuel pump relay. But it is doing it again. I dont know what to do
Sunday, April 11th, 2010 AT 11:29 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sunday, April 11th, 2010 AT 4:30 PM
