HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Tempo
Engine
Symptoms
Not Running
1993 Ford Tempo Car wont start
THOME1
MEMBER
1993 FORD TEMPO
1993 Ford Tempo 4 cyl Automatic
I put in a new battery, starter, and a starter solenoid in my car and it still wont start whyis that.
Sunday, September 28th, 2008 AT 8:31 PM
MECHANIC
Do you mean it doesn't crank the engine over or it cranks over but refuses to start.
Monday, September 29th, 2008 AT 4:50 AM
THOME1
MEMBER
All it do is make a clicking sound or crank the engine.
Tuesday, September 30th, 2008 AT 1:32 AM
MECHANIC
Double check the battery connection and at the starter-if okay start testing the ignition switch/park and neutral switch/starter relay/
Tuesday, September 30th, 2008 AT 9:09 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Car Will Not Start
My Car Wont Start. Check Fuel Pump, Relay. The Starter Wont Turn
Asked by
kellyr
1993
FORD TEMPO
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1993 Ford Tempo Car Cranks But Does Not Start
I Know That The Fuel Pump Is Running And Charging The Engine Before Start. I Have Replaced The Plugs, Wires, Coil, Distributor Cap...
Asked by
WSchoenke
1993
FORD TEMPO
1993 Ford Tempo Car Wont Start
Engine Mechanical Problem 1993 Ford Tempo 4 Cyl Front Wheel Drive Automatic I Have Had My Car Worked On A Few Times In The Last Few...
Asked by
amisener0889
1 ANSWER
1993
FORD TEMPO
Car Won't Start Unless I Push It.
Tried Replacing Starter Solenoid Which Is Next To The Battery. Also Had My Battery, Alternator And Starter Checked Out At Autozone, They...
Asked by
anticsea
1 ANSWER
1993
FORD TEMPO
1993 Ford Tempo Dies And Won't Start
By Process Of Elimination, I Believe The Problem To Be The Fuel Pump Relay Switch (changed Plugs, Wires, Rotor, Fuel Filter, Battery...
Asked by
fytnfyr
1993
FORD TEMPO
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
