1993 Ford Tempo
SUPERSALE
  • 1993 FORD TEMPO
1993 Ford Tempo 4 cyl Front Wheel Drive Automatic
MY CAR TRY TO START SOMETIME BUT IT WON'T START WHAT WHAT WRONG WITH THIS
ANY BODY CAN HELP ME
Sunday, July 25th, 2010 AT 9:28 PM
Cranks but no start condition-do below to determine whether it's fuel or spark issue.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sunday, July 25th, 2010 AT 10:29 PM
