1992 Ford Tempo won't start
RANDYPURL
  • 1992 FORD TEMPO
Electrical problem
1992 Ford Tempo 4 cyl Two Wheel Drive Automatic
this car cranks and the coil sprks only sporadically when it sparks the car fires but it is only once in a while
Monday, July 26th, 2010 AT 12:31 PM
FIXITMR
  • 9,990 POSTS
Could be the coil itself or maybe distributor cap/rotor or the hall effect coil on distributor shaft? When you say coil sparks, do you mean coil wire or just coil itself? These cars are notorious for bad coil wires, and/or internallly corrodes ends.
Tuesday, July 27th, 2010 AT 11:32 PM
RANDYPURL
The wire is good I got shocked! When it fires the car acts like it wants to start even through Me.
Wednesday, July 28th, 2010 AT 8:42 AM
FIXITMR
  • 9,990 POSTS
To test coil I usually unhook 1 end from distributor cap an stick sparkplug in it and lay it on someting metal on engine. Crank over and watch the spark. And yes, you can get a jolt if you hold/grab wire while doing this! I got some long plastic tongs just for this kind of work!
Wednesday, July 28th, 2010 AT 2:45 PM
