car was running fine. Went out it would not start. Cranks but won't turn over. Have replaced: fule filter, ignition coil distributor, router, spark plugs and wires. Still won't fire. 1: is there a way to test the tfi with out removing it. 2: is there also away to test eec with out special tester. 3: does ford let you get error codes from key on key off light flash
SPONSORED LINKS
Sunday, June 8th, 2008 AT 5:30 PM
