1992 Ford Tempo
CHISM104
  • 1992 FORD TEMPO
  • 4 CYL
  • 24,409 MILES
Everytime I drive my car I will come to a stop turn the car off, and when I go to start it all I hear is a click the car will not even try to start, the only way I can start it is by jumping it and banging on the starter with a hammer. It does not do it all the time but most of the time it will, any ideas I have a few but I would like your opinion
Tuesday, November 3rd, 2009 AT 9:57 AM
FIXITMR
  • 9,990 POSTS
Sounds like your brushes are worn out. Or a bad connection on selinoid. Which starter do you have old style or new. Large or small. The old style(large) has no selenoid at the starter itself. That starter has a ground connection that's a simple pinch under bendix cover. On the new style the ignition wire is a push on connector that can be loose/corroded or not properly connected.
Saturday, November 7th, 2009 AT 8:08 PM
DANNYR2009
  • 30 POSTS
True! I fixed mine by changing that push on connector on the starter !
Tuesday, November 17th, 2009 AT 10:22 AM
