1994 Ford Taurus Won't Crank But Jumps
STICKYLEFT
I have a 94 ford taurus with around 97,000 on it. Out of nowhere one morning the car wouldn't crank. We attempted to jump the car, and it started just fine. We let it run for about 25 minutes then turned it off and back on again, still no crank. You can hear it click when you turn the key, and all the lights turn on, wipers work, ect. We replaced the battery anyways. It still doesn't crank but will start off a jump. I'm not so sure where to go next with this. Any opinions?
Mar 15, 2006 at 4:35 AM
NOS
  • 320 POSTS
it really sounds like a bad connection to me. reason why i say this is if your jumping it and it starts you war clamping cables down on your battery and it starts. you are clamping against the terminals and it starts. did you put in a new battery or used ? check all you connections pos + and neg - ones at the solinoid also make sure your battery is good also. does the solinoid buzz when you try to start it with out a jump? is that is another sign of a bad battery or a very week one. (NOS )
Mar 15, 2006 at 12:12 PM
Suggested Repair
Check the battery cable connections at the battery and at the starter solenoid, both positive and negative. A jump that starts the car by clamping onto the terminals often points to a poor connection. Also confirm the battery is good; a buzzing solenoid when trying to start without a jump can indicate a weak battery.
Conversation Summary
The owner of a 1994 Ford Taurus says the car will not crank but starts with a jump. Turning the key produces a click, and the lights and wipers work. Replacing the battery did not fix the no-crank condition. The expert suspects a bad connection and recommends checking the positive and negative connections at the solenoid and verifying that the battery is good.
