Pull all the sparkplugs out and inspect for water in the cylinders and inspect the plugs.
Also check for spark-disconnect a plugwire or 2 and ground it to the engine-while cranking it over-do you have spark? If you got spark look for fuel
Pressure test it to confirm its the headgasket-
SPONSORED LINKS
Thursday, November 8th, 2007 AT 1:26 PM
