1995 Ford Taurus TOT Code 636
JAZZ0050
  • 8 POSTS
I have a 95 Ford Taurus SHO, 3.2L, Auto Transmission, 135K miles on it.
When I check the scan the PCM for codes it spits
out: 636 - Transmission Oil Temperature (TOT) sensor out of range - Transmissions.
Then it flashes 111 - System OK.
Is this normal ??
What do I have to do to fix the problem? Do I need a new transmission? Is it easy enough to fix myself?
Where would it be located?
Please help me.
Apr 9, 2006 at 1:52 PM
PEPPERMRJ
  • 1,158 POSTS
The transmission temperature sensor is either failing, it's connection is bad. or it's wiring is bad. Check the tranny lines to the rad for restrictions.
Good luck and let us know. :)
Apr 9, 2006 at 2:28 PM
JAZZ0050
  • 8 POSTS
Where the temp sensor be and is it hard to change?
Thanks
Apr 9, 2006 at 3:55 PM
Suggested Repair
Do not assume a new transmission is required. Test the transmission oil temperature sensor, its connector, and wiring, and check the transmission cooler lines to the radiator for restrictions.
Conversation Summary
The owner of a 1995 Ford Taurus SHO with code 636 (transmission oil temperature sensor out of range) asked whether a new transmission is needed, if the repair is DIY, and where the sensor is. The expert said the sensor, its connection, or its wiring may be bad and advised checking the transmission lines to the radiator for restrictions. Sensor location and replacement difficulty were not answered.
