1999 Ford Taurus Low Coolant Light
OSCARMEYER
My Low Coolant indicator is on, but the coolant level is perfect. I have checked and don't see any leaks. All coolant levels are correct and my temperature guage shows a normal temperature.
What causes the low coolant indicator to come on? A sensor must exist somewhere in the car.
This is a Taurus 6 Cyl - DOHC - 24V engine.
Thanks for your help.
Jul 23, 2006 at 7:51 AM
MIKEYBDMAN
  • 623 POSTS
Looks like the low level warning sensor is in the bottom of the radiator coolant recovery resevoir. They sit down in the bottom collecting crude until they read bad. You might be able to remove it, clean it, and have it work til the next time it gets crudy. Or just replace it. Should fix your problem.
Jul 23, 2006 at 8:45 AM
Suggested Repair
Clean or replace the low coolant level sensor in the bottom of the coolant recovery reservoir, which can foul with debris and trigger a false warning.
Conversation Summary
The owner of a 1999 Ford Taurus reports the low coolant indicator is on even though the coolant level is correct, there are no visible leaks, and the temperature gauge reads normal. The expert says the low-level sensor sits in the bottom of the coolant recovery reservoir and can collect debris until it reads bad, so cleaning or replacing it should fix the warning.
