1997 Ford Taurus No Heat
WOODYWARD
I have a 1997 Ford Taurus that is having a problem with the heating. I checked the water overflow bottle and it keeps losing water. When I fill it up and after a while having the car warrm up the water over flows out of the bottle. When I turn on the heater all I get is cold air coming from the vents. The Water pump was replaced and I took out the thermostate to make sure it wasn't locked up. But I still have the problem. My guess was that the heater core was no good, and that there was a blockage somewhere. Can you help.
Jan 16, 2007 at 4:27 AM
BOOTDOG
  • 665 POSTS
pull the heater hoses off and try flushing out the heatercore with a garden hose. keep flushing it out until the water flow is clear. also your heater contol valve may not be opening. make sure that you inspect it and it works properly.
Jan 16, 2007 at 7:26 AM
Suggested Repair
Disconnect the heater hoses and flush the heater core with a garden hose until the water runs clear. Also inspect the heater control valve and confirm that it opens and operates properly.
Conversation Summary
The owner of a 1997 Ford Taurus reports no heat, cold air from the vents, and coolant loss from the overflow bottle that overflows after warmup. The water pump was replaced and the thermostat was removed, but the problem remains; the owner suspects a bad or blocked heater core. The expert recommends flushing the heater core until the water is clear and checking that the heater control valve opens and works properly.
