2000 Ford Taurus Weak Heat
SLUGO
Hi-my car is a 2000 Ford Taurus 3.0, with 130,000+ miles. I just replaced the water pump because I have been having problems with only luke warm/cooler air coming out when the heat is on. (I live in WI, and it's hard to clear your windshield when only cool air is blowing out!) That seemed to help a little, but not enough. Other people have suggested that the heater core is shot. Where exactly is it located? What would be the EASIEST way to get to it?
Jan 15, 2007 at 1:34 AM
SERVICE WRITER
  • 9,123 POSTS
I would be more apt to think the thermostat is stuck open. The heater core is in the firewall on the passenger side. It can be backflushed by disconnecting the hoses at the core and running a hose with gentle pressure from the outlet hose, through the core and out the inlet.
Jan 15, 2007 at 2:21 AM
Suggested Repair
Check the thermostat first, since a stuck-open thermostat is more likely than a failed heater core. The heater core is in the passenger-side firewall and can be backflushed by disconnecting the hoses and applying gentle water pressure from the outlet hose through the core and out the inlet.
Conversation Summary
The owner of a 2000 Ford Taurus with over 130,000 miles gets only lukewarm or cool air from the heater. Replacing the water pump helped only slightly. The expert recommends checking for a thermostat stuck open and notes that the heater core is in the passenger-side firewall, where it can be gently backflushed.
