1997 Ford Taurus P0340 Code
FLASHHEAT
  • 8 POSTS
I have a 1997 Ford Taurus 3.0L SOHC. During my last smog test I failed with a PO340 trouble code. I was curious if it could mean anything else than a bad camshaft position sensor?
Feb 26, 2007 at 2:33 PM
SERVICE WRITER
  • 9,123 POSTS
It sure could and probably does. Under the cam sensor is a syncronizer that is also probably bad. A window gets bent on the syncronizer that wipes out the sensor as well. You'll need a special tool to change that.
Feb 26, 2007 at 9:33 PM
Suggested Repair
Inspect the camshaft position sensor synchronizer under the sensor. A bent window on the synchronizer can damage the sensor, so both may need replacement using the required special tool.
Conversation Summary
A 1997 Ford Taurus 3.0L SOHC failed a smog test with code P0340. The owner asked whether that always means a bad camshaft position sensor. The expert said the synchronizer under the sensor is also likely bad, because a bent window can wipe out the sensor, and a special tool is needed to replace it.
