1995 Ford Taurus Dome Light and Cruise
BUSGSY4U2
i have a 1995 ford taurus with 247,xxx miles. the dome light stays on all the time and the cruise control has stopped working. the check engine light comes on and off all the time. any ideas of what might be causing all of this? thanks.
Nov 9, 2006 at 2:18 AM
E40WATER12
  • 522 POSTS
Well for the dome light to stay on, Possibly the switch has wornout, For youre cruise control, Is more likely relay or switch is wornout too, For youre check engine light kicking on, U need to get the trouble codes scanned.
Good Luck.
May 22, 2007 at 7:23 PM
Suggested Repair
Check the dome light switch for wear, inspect the cruise control relay and switch, and scan for trouble codes related to the intermittent check engine light.
Conversation Summary
The owner of a 1995 Ford Taurus with high mileage reports a dome light that stays on, cruise control that no longer works, and an intermittent check engine light. The expert suggests a worn dome light switch, a worn cruise control relay or switch, and scanning for diagnostic trouble codes.
