1998 Ford Taurus SE Surges in Drive
1998 FORD
JONMILLS76
I just purchased this car and it has 80,000 miles, the service engine light came on and now when you put it in drive and dont touch the gas pedal it begins to go and it jumps and the speed goes up and down. What could this be? it is a V6 with an automatic transmission
Mar 14, 2006 at 7:26 AM
PEPPERMRJ
  • 1,158 POSTS
First place to start is to have the codes pulled and post back. :)
Mar 14, 2006 at 12:03 PM
JONMILLS76
EGR flow excessive, what does this mean and what do I need to do to fix this problem
Mar 14, 2006 at 2:17 PM
PEPPERMRJ
  • 1,158 POSTS
"EGR stands for Exhaust Gas Recirculation. It is part of the vehicle emmissions system, and is used to reduce combustion temperature and pressure to control Oxides of Nitrogen. There are generally three parts to the EGR system: the EGR valve, an actuator solenoid, and a differential pressure sensor (DPF). These things work together to deliver the correct amount of recirculation based on engine temperature, load, etc. The P0402 code means that OBD detected an excessive amount of EGR.
SymptomsYou may notice drivability problems such as the engine may surge off idle. There may also be other symptoms.
CausesA code P0402 most likely means one or more of the following has happened:
The DPFE (differential pressure) sensor is faulty and needs to be replaced
There is a blockage in the EGR (most likely carbon buildup)
The EGR valve is faulty
The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions With a P0402, it is common for people to replace the EGR valve, only to have the problem return. The most likely solution is to replace the DPFE sensor.
Check the voltage at the DPFE sensor both at idle and when the EGR is open
Replace the DPFE sensor"
The above is a more technical answer. The shorter story is that ehaust fumes are sucked into the engine to lower pollution. The passage from the exhaust to the engine intake is important also. Some time on higher mileage vehicles soot from the exhaust builds up and will not let the valve close. It is only supposed to be open when the engine is running fast.
The least expensive repair might be to simply clean EGR the port and valve with carb cleaner and an old toothbrush.
Ford has had problems with their DPF sensors. These let the computer know what is going on with EGR flow. The will fail and give false information. The computer then does things it shouldn't. This would be the next thing I would test and/or repair/replace.
Good luck and let us know. :)
Mar 15, 2006 at 12:36 AM
Suggested Repair
Confirm the P0402 excessive EGR flow code. Clean carbon buildup from the EGR valve and ports with carburetor cleaner. If the surge continues, test and replace the DPFE sensor, a common Ford failure that can cause false excessive-flow readings. Also verify the EGR valve is not stuck open and has proper vacuum.
Conversation Summary
The owner of a 1998 Ford Taurus SE with a V6 and automatic transmission reported a service engine light and surging or jumping in drive without pressing the accelerator. Codes showed excessive EGR flow (P0402). The expert explained that the EGR system recirculates exhaust to control emissions and that a faulty DPFE sensor, carbon blockage, or a sticking EGR valve can cause off-idle surge. Recommended steps were to clean the EGR valve and ports, then test or replace the DPFE sensor.
