1997 Ford Taurus Door Ajar Light
MDJELDER
Our 1997 Ford Taurus (144,000 miles) must have a short somewhere but we can't figure out where. The "door ajar" indicator light won't go off no matter how many times or how securely we shut the driver side front door (the only one that seems to be involved). The two interior lights (dome and map) also stay on all the time now, since the car seems to think the door is always open. We can't find the sensor on the driver side front door to see what the problem is. All we've been able to do at this point is remove the two interior bulbs so they don't get too hot. Any suggestions?
Jan 3, 2007 at 9:10 AM
SERVICE WRITER
  • 9,123 POSTS
Need to lube the door latchs with a thin lube like wd 40, clean it first with brake clean. Open and shut many times while lubing them.
Jan 3, 2007 at 9:31 AM
MDJELDER
That seems to have done the trick - thanks!
Jan 5, 2007 at 10:18 AM
SERVICE WRITER
  • 9,123 POSTS
My pleasure :D
Jan 5, 2007 at 11:09 AM
Suggested Repair
Clean the door latches with brake cleaner, then lubricate them with a thin lubricant such as WD-40 while opening and closing the door several times.
Conversation Summary
A 1997 Ford Taurus had a door ajar light that stayed on and interior dome and map lights that would not turn off, as if the driver door remained open. The owner could not locate the door sensor and had removed the bulbs to prevent heat. An expert recommended cleaning the door latches with brake cleaner and lubricating them with a thin lubricant such as WD-40 while cycling the door. The owner reported that this resolved the issue.
