interior dome and door lights stay on
245,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
MUGGSY541
My interior dome light and door lights stay on. Ive made sure all the doors and trunk is closed properly. The indicator light on the dash comes on. I have been disconnecting the positive terminal in the post.
Some times the lights work properly. But if I have a bunch of stops it eventually wont work properly
Mar 29, 2015 at 1:56 PM
WRENCHTECH
  • 20,758 POSTS
The switches that control the lights for open doors are made right into the door latches and they have a history of sticking and causing problems like that.
Here is a technique that often works well and eliminates the problem at no cost.
Get a can of spray lube like WD40 or something like it and has a straw on the nozzle. Spray it generously up into the latch mechanism. Now open and close the door numerous times to work it in. Repeat this process several times. Since you don't really know which door is causing the problem, you should do all of them. It's usually caused by the most frequently used door but it's not guaranteed to be that one.
Mar 29, 2015 at 7:18 PM
