1998 Ford Taurus Lean Codes
ZOGGIN
  • 9 POSTS
What do codes p1131, 1132, p1130, and PO 0310 mean?
I have 1998 ford taurus se with a 24v 3.0L v6. What do I need to do to fix this problem?
Jan 25, 2007 at 8:48 AM
SERVICE WRITER
  • 9,123 POSTS
Hey Zog<
The 0310 is a misfire detection that should be ignored at this point. The other ones are a lean condition that is being corrected by increasing the richness. Start with a fuel pressure check for specifation being too low.
Jan 25, 2007 at 9:26 AM
Suggested Repair
Ignore the P0310 misfire code for now. The other codes indicate a lean condition being corrected by added fuel. Start by checking fuel pressure against specification for pressure that is too low.
Conversation Summary
The owner of a 1998 Ford Taurus SE 3.0L asked what codes P1131, P1132, P1130, and P0310 mean and how to fix them. The expert said P0310 is a misfire detection that should be ignored for now, while the other codes indicate a lean condition being corrected by increasing fuel richness. The recommended first step is a fuel pressure check for pressure below specification.
