2001 Ford Taurus Y-Pipe Removal for Oil Pan Fix
RKUHMAN
2001 Ford Taurus SES 80,000 miles with 282 cid (3.0L) Vulcan engine. Engine code is "2" (flex fuel) which is same as engine code "U". Replacing the oil pan gasket requires removal of the exhuast Y-pipe. I am not able to get the rear or the Y-pipe, i.e., the catalytic converter, out. There does not appear to be adequate clearance between the front of the engine, the frame and possibly the axle. The repair manuals I have read indicate it should just slide out after the Y-pipe is separated from the exhaust manifolds and the exhaust pipe. Is there some trick I'm missing or is additional disassembly necessary?
Dec 10, 2006 at 3:51 PM
CARUNDELL
  • 602 POSTS
[quote:fb580e345c="RKuhman"]2001 Ford Taurus SES 80,000 miles with 282 cid (3.0L) Vulcan engine. Engine code is "2" (flex fuel) which is same as engine code "U". Replacing the oil pan gasket requires removal of the exhuast Y-pipe. I am not able to get the rear or the Y-pipe, i.e., the catalytic converter, out. There does not appear to be adequate clearance between the front of the engine, the frame and possibly the axle. The repair manuals I have read indicate it should just slide out after the Y-pipe is separated from the exhaust manifolds and the exhaust pipe. Is there some trick I'm missing or is additional disassembly necessary?[/quote:fb580e345c]
Hey RK
You may have to do a bit of "creative yanking" or "creative prying" ....... carefully of course, but it should come out, just be cautious of the O2's.
Chris
Dec 11, 2006 at 4:04 AM
Suggested Repair
After the Y-pipe is separated from the exhaust manifolds and exhaust pipe, carefully pry or maneuver the catalytic converter section out. Extra disassembly is not indicated; protect the oxygen sensors while working it free.
Conversation Summary
The owner of a 2001 Ford Taurus with a 3.0L Vulcan engine cannot slide the exhaust Y-pipe and catalytic converter out for an oil pan gasket replacement, despite separating it from the manifolds and exhaust pipe, because of tight clearance near the engine, frame, and axle. The expert says it should come out with careful prying or maneuvering and advises caution around the oxygen sensors.
