1997 Ford Taurus removal of the "y" crossover exh
22,000 MILES • 6 CYL • FWD • AUTOMATIC
FJNELSON52
I am replacing the oil pan gasket and need to drop the y pipe from the exhaust manifold. I have the front off, that was easy, but the rear one is a bugger. I can get a sockect on it with a wiggler and and extension, 1/2" drive. I have to use a 12 piont regular socket because the only impact sockets I have are deepwell. That is the rear bolt on the manifold I can't even see the front bolt on the rear manifold. How do I get it off?
Feb 8, 2009 at 2:55 PM
BILLYMAC
  • 2,204 POSTS
hi the 12 point socket will most likely cause you big probs as in rounding the bolt off and then you have real probs. i would go buy the right 6 point socket much cheaper in the long run. you can,t see the front bolt but you can feel it with your fingers and a swivel extension and a large breaker bar will get it off.sometimes you have to use your eyes in your fingers lol. billymac
Feb 9, 2009 at 8:48 AM
