2-3 months ago I did a front engine cover gasket replacement. I had to replace the oil pan gasket in the process. The service manual said about 106 ftlbs for the bolts. I thought that was extremely high (actually broke one bolt using the torque wrench before I just torqued by feel). Now the gasket is pushed out from between the pan and the engine. Was it to tight? What torque should I set it at? Or is it something else?
Oct 15, 2009 at 12:33 PM
