1995 Ford Taurus Dies, No Fuel Smell
DURANXRE
I was recently told that to replace my fuel pump on my 1995 Ford Taurus, 90,000 miles, fuel injector 3.0, it would cost 480.00. Can a person like myself put a fuel pump on and the fuel filter. As I was driving my car, I went to accelerate around a slower car when my car cut off. I tried to start again, but it would not turn over. It tried. However, as I pump the pedal, I noticed that there was no scent of gas being pump into the engine. Everyone has told me that I need a new fuel pump. Can I access it easily?
Jul 25, 2007 at 5:25 AM
  • 75,988 POSTS
[quote:9fbf1a77bf="duranxre"]I was recently told that to replace my fuel pump on my 1995 Ford Taurus, 90,000 miles, fuel injector 3.0, it would cost 480.00. Can a person like myself put a fuel pump on and the fuel filter. As I was driving my car, I went to accelerate around a slower car when my car cut off. I tried to start again, but it would not turn over. It tried. However, as I pump the pedal, I noticed that there was no scent of gas being pump into the engine. Everyone has told me that I need a new fuel pump. Can I access it easily?[/quote:9fbf1a77bf]
Check the fuel filter,fuel pump relay,inertia switch before you get to the pump, if the 3 checks-out,do a fuel pressure check.
Jul 25, 2007 at 10:28 AM
Suggested Repair
Before replacing the fuel pump, check the fuel filter, fuel pump relay, and inertia switch. If those check out, perform a fuel pressure test.
Conversation Summary
The owner of a 1995 Ford Taurus with a 3.0 engine and 90,000 miles said the car cut off while accelerating and would not restart, with no fuel smell when pumping the pedal. A shop quoted $480 for a fuel pump, and the owner asked whether the pump and filter could be replaced personally and accessed easily. The expert advised checking the fuel filter, fuel pump relay, and inertia switch first, then doing a fuel pressure check if those are good.
